Heres a challenge - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2003, 08:31 PM
Post Heres a challenge
My 81 el camino dies the other day after it ran for the first time in 6 months. It had good spark so i figured the old gas gunked up the carb so i rebuilt it. I disconnect the gas line from the carb and spray starter fluid into it and it doesnt even kick over. I take a plug out and i see good spark. What could the problem be? If its timing how could of it have changed it was just running crappy but it was running. please help
Old 03-17-2003, 09:03 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
[quote]Originally posted by jeff germano:
<strong> I disconnect the gas line from the carb and spray starter fluid into it and it doesnt even kick over. I take a plug out and i see good spark. What could the problem be? If its timing how could of it have changed </strong><hr></blockquote>
Spray the starting fluid/Ether in to the choke horn.......
Old 03-17-2003, 11:40 PM
4 Jaw Chuck's Avatar
Post
...and tap around the carburator with a screw driver, just lightly.
If that don't work...BOOST it! :p
— Han Solo
Old 03-18-2003, 12:25 AM
senor_limpio's Avatar
The Dude
Post
Probably a little late now, but anyway....
Pull all those plugs and let 'em dry out. (Might as well give those plugs a cleanin' while they're out!)
Señor
[ March 18, 2003: Message edited by: senor_limpio ]</p>
Old 03-18-2003, 11:49 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
.....All the above.....
Old 03-18-2003, 03:24 PM
bigwildgrin's Avatar
Rooster
Post
if you let your car sit for six months it could be water in the gas. this is especially true if the tank was half full or less; condensation forms on the inside of the tank if it is not completely full of gas. just a thought since you said it started and then died...
