Here's a little BBC that could. . . . - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2005, 02:48 PM
. . .my customer is putting this in a 18ft jet boat.
Old 09-29-2005, 03:02 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
sweeeeeet
Looking good!
So what are the numbers?
Old 09-29-2005, 03:04 PM
820HP at 7200 rpm
679#/ft at 5500
Corrected
For a 468 CID its a nice piece. Here is the graph:
engineczar's Avatar
pulling the skier out of the water won't be an issue
BSE Racing Engines
Old 09-29-2005, 03:16 PM
. . .no pulling a skier should be the least of his worries. Dyno numbers are dyno numbers but what impresses me is the torque band. For a small BBC it is just pancake flat. I told him it ought to feel good from any rpm range when he stabs it.
Chris
Old 09-29-2005, 03:50 PM
What heads are you using?
Old 09-29-2005, 03:56 PM
Canfield 310's with extensive port work.
1.7 to 1.8 ratio BBC rockers much diff...? Bumpstick Engine 6 04-29-2005 12:41 AM
sbc and bbc rockerarms taonindo Engine 22 02-18-2005 12:31 AM
gas milage on a bbc 427 bet on black Engine 18 01-03-2005 01:32 PM
14015445 Bbc ?? terror385 Engine 6 10-19-2003 01:08 PM
BBC Comp cam EX274H, Impala5967 Engine 2 10-01-2003 09:53 AM
