Here's What I have. Need Help with Rest - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 06:43 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Ok guys I know you are all probably watching the election results but I need help with my decision. Here is what I have to work with. Please make suggestions with what I have because it is all I got for now.
1989 Chevy S10 (inside stripped to lessen weight)
No factory glass, all lexan and plexiglass
Tubbed & Narrowed w/ Frame boxed
9" Narrowed Rear w/456 gears & Auburn Full Spool
33x16x15 Hoosier Slicks
BBC 402 (numbers say it came in a 72 Camaro)
781 oval port heads
Offy Tunnel Ram w/ (2) 600 Edelbrock Carbs
TH400 Tranny w/Transbrake
I do not know much about the motor other than it does run fine. As far as the cam specs, that is unknown too. I have to assume the motor and heads are stock because I can't afford to tear it down right now to see. I am just trying to get back to the track by next season. My question is, what would be the best cam & stall converter for this setup? I am to the point of wanting to install the tranny to get the driveline complete but I don't want to put too big a stall in nor too small a stall. My "guess" would be a 3000 - 3500 stall. What do you all think. I would like a good lopey idle with the cam. All help would be appreciated. Thanks
Name:	S10 BBC Motor 006.jpg
Old 11-05-2008, 03:59 PM
S10 Racer's Avatar
781 oval port heads
Can someone help me here?
Old 11-05-2008, 04:24 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I don't know much about BBCs, but maybe can help a bit.
Do you know what your compression ratio is?
I would start looking at cams with at least 230 degrees of duration at .050, maybe up to the mid 240s. If your compression ratio is low I think a cam on a 108 LSA could help.
Call a few cam companies they know some stuff!
Old 11-05-2008, 09:21 PM
Banned
because of your limited compression and lack of rear end traction I would go with a 2500 stall, it'll help keep the tires planted on the launch.
Old 11-05-2008, 10:03 PM
You should really look for some closed chamber large oval port heads. Using 781 heads on a 402 is almost impossible to make decent compression without having to use mega dome pistons.
You have the rest of the day off. cboy Off-Topic 11 01-12-2008 10:13 PM
The REST of the stroy about Kurt Busch's drunk driving arrest Centerline Hotrodders' Lounge 29 03-21-2006 08:07 PM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 02:51 PM
Smart parts arm rest Streetrodfan Interior 2 11-13-2004 11:00 PM
I'm Painting A Door,,,how Do You Blend With Rest Of Truck? STATUTORY GRAPE Body - Exterior 2 12-05-2003 06:29 PM
