I recently had an issue with spark. It now has brand new cap/rotor/module/coil and a repaired CD ignition box (All mallory)
Car starts now and it runs fine. I can have it sit and idle in my driveway all day long at 170*
I went to get gas and drove about a mile to the station - filled up and on the way back home i got on it pretty good then just was cruising. It began to bog/hesistate then just died. Pulled over hit the key and it fired back up - drove about 1/4 mile and it began to happen again. Pulled over hit the key and it fired back up.
Checked my fuel pressure and it was at about 5 PSI so i upped it to 6.5 same thing is still happening.
When i mess with the mixture screws and idle in the driveway the car runs great it will just run. When i go to drive it it happens again.
Engine info
Demon 750 silver claw (flows 900cfm)
Electric pump - inline filter - bypass with return line
fresh 454 10:1 CR
comp magnum 280H 230/230 @ .050
Before my spark issues the car was running fine. I would drive it on 50 mile trips with out this issue. I was having some fuel issues at the same time so there have been tweaks to the carb and its been pulled apart a few times to clean it up.
Currently the fuel mixture screws are set at 1 1/2 turns out and i am getting some black soot on the driveway from idling so its running rich but i dont think that would make it hesistate, then get to the point it bogs so hard there is NO power and i have to hit the key to turn it off or it just dies. But it starts right back up like there was no problem....
Halp!
