hesitation - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2007, 07:24 AM
racer rick's Avatar
hesitation
i am trying to help a friend tune his race car.his problem is that the car runs strongoff the line but when his rpm hit 3500 the engine come to life with loads of power.it is a bilut 302 .11.5 comp.colt cam thatmakes power from 1500-6500rpm.2500 stall converter. he thinks it is timing issue.what is the best way to recurve the distrib.it is an aftermarket msd unit.should he take it toa shop that has an distrib.machine?
Old 10-10-2007, 12:18 PM
Put a MSD crank trigger,msd 6Al box, multi-step retard system(for retarding timing at cranking), and an old style chevy dist. with all the guts taken out and welded up.
The motor fires up and then runs at total advance at all times, thus eliminating any timing fluctuations.
After I put my first crank trigger system on my race car, you could not pay me to run any other type setup (distributor).
Initial cost is not cheap , but elimination of all problems is worth it in the long haul.
Consistency wins races!
4.3L Hesitation Problem... drluv Engine 5 07-11-2007 06:42 PM
Hesitation on 350 trenchdog73 Engine 16 04-11-2007 11:03 AM
hesitation on feul injected engine corsair1961 Engine 3 06-08-2006 12:28 PM
Hesitation! frankenvette Engine 17 05-18-2006 04:55 PM
Holley hesitation harrassment Neal Green Engine 12 11-25-2004 11:36 PM
