Hesitation upon accelaration 00 Chevy C2500 3/4 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2012, 10:19 PM
A friend e-mailed me a thread today after my problems with my truck recently. I love my truck but don't have a lot of mechanical experience. I recently had the fuel pump, fuel pressure regulator, and fuel filter replaced. Runs good in general, but when I take off periodically it has hesitation, almost like I'm in water. It doesn't happen everyday or all the time. After reading another thread on here tonight, I'm beginning to think I need to check/change the EGR. My problem is knowing where it's located on my vehicle. When I do find it, can I clean it or is it better to just replace it (new or used). I bought my truck used last year and it's run great for me until last month. I originally replaced the parts because as I would give it gas it would bog down without quite dying, then I was able to feather my gas pedal back up to speed. Replacing the fuel pump etc. got me back on the road but I am having the same problem periodically. PLEASE HELP! I want to try replacing the EGR, I just need to know where to find it and I need to know how to replace it. My truck is a 2000 Chevy C2500 3/4ton. Any advice would be really appreciated!
Old 07-28-2012, 06:41 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Start here:
Chevrolet Silverado and GMC Sierra Repair Manual for 1999 thru 2006 Full-size Light-duty Gasoline Engine Models. Includes 2000 thru 2006 Suburban, Tahoe, Yukon, Yukon XL, Sierra Denali. 2001 thru 2006 Yukon Denali. 2002 thru 2006 Chevrolet Avalanche.
This is the best money you can spend seeing you don't have much mechanical experience.
Will 1950 Chevy 1/2 ton pickup parts fit a one ton of same year? Hunt89dan Hotrodding Basics 3 06-11-2012 09:06 PM
chevy 1950 3/4 ton to 1/2 ton solid axle swap 3/4ton flathead Suspension - Brakes - Steering 5 02-20-2011 07:58 PM
Convert 89 Chevy Pickup 1-ton to 1/2 ton unstable Suspension - Brakes - Steering 5 04-10-2010 07:51 PM
88 chevy 2 ton cab to 80 3/4 ton frame stoneyone2001 Body - Exterior 1 11-11-2003 08:43 AM
Oil pressure under hard accelaration christopher406 Engine 3 01-08-2003 11:55 AM
