Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hey Barry, Hey Martin 15 degree rule
Old 01-29-2006, 06:32 AM
adtkart adtkart is offline
To try to clarify this, If you have the reducer for that temperature range, you still adjust the times, according to the temp difference from 70 deg? If the recommended flash time is 15 minutes, and it is 85 deg, you've got to spray the next coat at 7 minutes, and not wait the 15 minutes? Doesn't it work to your advantage to wait that extra time to avoid solvant pop?
