Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hey do i need to brase the cab of my short cab pic up befor lifting it off my frame
Old 07-18-2004, 10:52 PM
crazy larry's Avatar
crazy larry crazy larry is offline
Last journal entry: better comparison before and after shots
not sure on the particulars of your truck, but what's involved is,
  • disconnect all wiring
  • disconnect all linkage (tranny, throttle, clutch, brakes etc....)
  • unbolt the cab.
  • if the doors are on and closed, no bracing should be required, if doors are off, then bracing might be needed. if it's a good solid cab, i wouldn't worry to much about it. I've removed old ford cabs without doors or bracing, and they stayed straight.
  • pick that heavy mutha up.
it is possible i forgot something, if i did, someone will let me and you know.....
