New addition: When we turn on switch for Aux. electric fan, second set of front turn signal ( have two sets of front turn signals) come on and fan runs at half speed. Half speed might be caused by lamp load being in same circuit and eating up some of the voltage. Car was recently in Body Shop but all seemed okay in drive home and was NSRA Inspected about three weeks ago?? Confusing..... THANKS.... THERESA
HEY! Did solve fan problem. Found that front turn signal and Aux. fan had common ground wire and it had come loose. Aux. fan is back at full speed and second set of front turn signals don't come on. Still have problem of no turn signal and all four light coming on when brake pedal is depressed ? ? ? Think that be something in flasher circuit?? THERESA
Short
Doc here,
Sounds like you may have a short in the steering column , column plug or the flasher switch itself. This is the Only place both those circuits have common contact. Is this an aftermarket column? like a GM ADJUSTABLE? Those usually chafe and short at the column universal inside... THE CLUE here is when you step on he bakes all four lights come on.. The only other way those two circuits could have common contact would be if you put a single Filament lamp in a duel element socket. Also, Something like a rear seat spring or spare tire cutting the harness and shorting it..I should think were that the case, you'd blow fuses too.. Ohm out (by now you should be failure with this drill..) the column harness for switch and brake lights, be sure none have contact to each other, or eliminate any you find (signal switch off) Check to insure proper grounding all the way from flasher to lamps...(you may have a "Loaded ground" robbing power from a nearby series ground...(like you had with the fan...classic example...) Then check the fuse..because if you draw source power in series through a nearby circuit...and it's not semi conductor (or polarity sensitive) you can almost bet source power is open. You said it was in the body shop, would the happened to change any bulbs? That would be another clue... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thanks Doc: We will be on it again today. Will start checking at steering column connector to see what we can see. I just love these multiple problems all packaged in one. Column is out of a 70's Firebird and is a tilt... THANKS... THERESA
Doc: Here is another hint. We did notice that ocassionaly both turn indicators would glow ( they are LED in digital panel) but turn signals always worked when needed? I wonder what was causing them to glow? Must of have been power leaking to ground somewhere for both to glow??? THERESA
Hey Doc:
Solved problem!! Pulled steering wheel and moved wires around and everything started to work correctly. I guess you were right in that problem was in tilt steering column. I would hate to take that thing apart, WOW so many little parts that look very delicate to work with..... THERESA |
turn signals
Doc here,
I had a feeling you'd find it there...Common problem in tilts. It's not as hard as it looks..use a digital camera if necessary, to map disassembly, once you get the mechanical out of the way, It's easy to slip the harness / switch ring out and repair or replace. The Glowing L.E.D is indicative of a reverse bias on the diode...could have been caused by the harness, but also a faulty Charge system (very first signs) may be the cause. Keep us posted on the progress! Doc
| hey hey hey! | inspiron | Introduce Yourself | 16 | 11-18-2010 07:31 PM |
| Hey Hey! | boofis | Hotrodding Basics | 17 | 03-12-2005 02:02 PM |
| hey hey | JimmyP | Introduce Yourself | 2 | 12-03-2004 02:17 PM |
| Points question (Hey Doc!) | garretthes | Engine | 14 | 09-26-2004 09:13 PM |
| Hey Hey | 750HP305TPICAMARO | Hotrodders' Lounge | 9 | 08-24-2003 08:08 PM |
