Looks like an 7.5" out of an Aerostar Van, Bronco II or non-4.0 Ranger to me.
I believe that's a Dana 44 which could have come out of a Ford truck.
Edit - upon closer look my call is not correct. No drain plug on back plate and the "hump" is not quite right.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
(IMO), the easiest way to go to CHEV is to use hardened aftermarket axles drilled for the bolt pattern and then mount an aftermarket GM rear disc kit to it.
to Ford or not to Ford
I wish the owner/s would go with Chevy but they wanted it all 4ord for some reason , I have never seen such a hack job like this 37 as far as workmanship and odd ball stuff . I was hoping there was an EZ fix but it appears this project is going to be just one headache after another .
I appreciate all the feed back from all you guys just wish they would go GM . I was thinking there could be an axle swap to get the 4 3/4 on 5 but so far no dice but the white fuzzy's on my rear view mirror. This all started with just putting in a new radiator in and now I have a big can of worms .
4 3/4" on 5 is mainly a GM pattern. Aftermarket hardened axles are actually cheaper than OEM replacements. That will give you the wanted bolt pattern. I would also think it cheaper to buy an aftermarket GM disc swap that trying to track down a four wheel disc MUSTANG...
Wait a minute. The MARK VII/BIRD/SVO swap is 11" if I remember correctly. All you have to buy new would be the axles, which is like cheap insurance actually. |
Trees |
Thanks A Million Guys
these people got raked over the coals by whom ever did the "HACK JOB" for them 3 years ago and if I didn't know them this unit would of been down the road after the radiator job . I by far are not nor clam to be a rod builder but a blind man could of bone better then what was done to on this rod .http://hotrodders.com/gallery/showph...cat/500/page/8 I just called him and told him of the great feed back from all you guys and now I think we're going for the rear cheby with disk and get this thing out of my shop ,plus I don't see nothing but problems with 4ord rear disc on this diff in the truck. I can't thank ALL of you guy's enough for the input your help is much appreciated . I figured since we have a 3 day show to go to on Aug. 25/26 & 27th the idea of cheby parts would change their mind . Happy rodding guy's
Looks like a 7.5" to me, especially when you look at the bolt pattern. Then again I'm no butt expert.
Back to square 1 ... maybe ?
, but that still leaves me with a dead end puttin bigger disc on that rear and a 4/3/4" on 5 ... doesn't it ? Now I know why I like Chevy's . now this lead may make my life Ezer ..maybe
It's a 7 1/2" RG and is a piece of crap. Your referral to the owner wanting ALL FORD most likely means he thought he was getting a 9" transplant.
Somebody suckered him. I bet the whole shop had a cigarette after that...
| 8.8 Ford rear end in my 79 G body Malibu | 79 Malibu327 | Transmission - Rearend | 4 | 05-20-2007 02:26 PM |
| Max rear wheel size 34 Ford | 302 Z28 | Suspension - Brakes - Steering | 13 | 10-11-2006 07:19 AM |
| Ford rear main seal question. | el pollo | Engine | 3 | 07-15-2006 09:12 AM |
| 1945 ford p/u rear leafs,to keep or not to keep | biglee550 | Suspension - Brakes - Steering | 8 | 04-25-2005 07:05 PM |
| rear differential for 46 ford | rp1 | Suspension - Brakes - Steering | 1 | 09-08-2003 07:43 AM |
