hey guys - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2006, 09:14 PM
hey guys
hey guys
would any one know the mesurements of a 96 chevy s-10 rear from backing plate to backing plate?
thank you
Dan
Old 06-15-2006, 10:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
58"
That measurement was found here
:http://www.quickperformance.com/Tech...us_measure.htm
I saw that link on another thread here recently. You can find it in the knowledge base too.
hope this helps, Mikey
BE different....ACT normal.
Old 06-18-2006, 09:20 PM
I believe the 2 wheeled drive is 48" and the 4X4 is 52" from backing plate to backing plate. The 2 wheeled drive is 54" and 4X4 is 58" from hub/rim mating surfaces. The 4X4 is 4" wider than the 2 wheel drive.
hey guys squidgy Introduce Yourself 2 02-25-2006 09:49 AM
Hey Guys Rojo01 Introduce Yourself 3 02-15-2006 04:06 PM
hey guys whats up chevykid454 Introduce Yourself 2 01-07-2006 06:50 PM
Hey guys i got the motor running good 302truck Engine 6 01-22-2004 05:54 AM
Hey guys.... Jeffrey03 Engine 4 01-13-2004 07:38 PM
