"Can you guys tell me if i can set my timing with a standard timing light ..I have been told that my timing should be around 32 to 34.. Is there any way that i can do this with a standard timing light "
Yes you can, but you need some timing tape. You can get it for around $6-$10. |
Hook up your timing light. Warm up your engine to operating temp and then dis-connect the vacuum advance hose from the distributor and plug it. Re-connect this hose AFTER you have set the timing. Increase the engine RPM to around 2500-2800 and check the timing. You will read the amount of advance where the pointer lines up with the degrees on the tape. Adjust your distributor as required to the timing you want. Try 34-36 degrees as a starting point. If you get any pinging when using moderate throttle in high gear going up a slight hill; back off the timing 2 degrees and re-test. |
timing marks
You can also do it another way.
Take the diameter of your balancer X 3.14159 Then divide that answer by 360 This will give you what 1 deg is, in inches around the outside of the balancer. Then take that answer x the number of degrees you want. example 8.0" balancer 8.0 x 3.14159=25.13272 divided by 360=.069813 x 36 degrees of total timing =2.51327 So if you take a flexable tape and measure from the 0 mark 2.51327 and mark your balancer. that would be 36 degrees with you standard light. keith |
