hey i have backfiring issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2013, 06:17 PM
I have a 76 firebird with a 455 rocket and it backfires heavily and i believe it is fron the carb but there is no soot or anything at all, when i put the gas peddle down.it loses power and.backfires
Old 05-12-2013, 07:43 PM
vinniekq2's Avatar
check your timing. check the plugs & wires. is the engine stock or hi performance? did this just start happening all of a sudden?
Old 05-12-2013, 08:18 PM
life is a temporary assignment
If all else check's out fine,, Could be a rounded lobe on the cam..
Old 05-12-2013, 08:39 PM
Check timing and also where you have the vacuum for advance connected to the carb. If you are running a HEI distributor, try connecting the vacuum line to the ported connection rather than the port below the throttle plates. While you may have correct timing readings with the vacuum line disconnected, see how much you have when it is connected at idle. If the vacuum advance is not limited, you could be adding a lot of timing at idle that you don't see unless you check for it with a dial back light. I have seen a vacuum can on an HEI that had 22 1/2 degrees that it added at idle when connected to the full vacuum port on the carb. It will cause the popping and backfiring up through the carb when you try to come off idle.
Old 05-12-2013, 11:29 PM
Hm i will post a vide and yes it just started happenning car was faster then a bat out of hell before this and i believe it is performabce maybe
back firing
Backfiring issues Linez35 Engine 3 08-16-2010 11:03 PM
backfiring 79chevy4x4 Engine 32 01-20-2007 03:37 PM
backfiring 1980Impala Engine 5 03-15-2004 05:34 PM
backfiring zipfactor Engine 13 11-09-2003 09:28 PM
backfiring 55relic Engine 10 06-07-2003 07:41 PM
