Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge > Introduce Yourself
  #1
Old 10-02-2007, 06:43 PM
stroked87monte stroked87monte is offline
hey yall
Hey yall, gonna drop in here and tell on myself. Name is Brian, I'm 37 and I live in North Carolina. I have a few projects that I have been working on.
First off I have a '90 Suburban 4x4 that has been lifted 4 inches has 35x12.5x15 tires, a Warn 12,000 lb winch, and has 4.11 gears. It has some other stuff also. When I want to go in the mud I swap out the street tires and put on some Mickey Thompson Baja Claws.
Next is my first 1987 Monte Carlo SS Aerocoupe, Burg/Burg inside with T-tops. It has a 383 stroker usual stroker parts, Bowtie heads 202 and 160 valves, some minor porting. RPM Airgap with a 750 Demon on top. Got a .515 bumpstick, some Comp Cams 1.5 roller rockers. Other good things, Flow Tech headers, true duals with Warlocks. I put in a TH350 and an unknown stall and using the stock 3.73 gears. I removed the AC system and put in a non AC setup from a Cutlass, so it looks factory.
My second '87 Monte Carlo SS Aerocoupe white/grey inside. It is currently going through an engine swap. The stock 305 took a dump so I am putting in a 305 TPI motor from a '90 IROCZ. Its got Edelbrock TES headers, hollow cat, duals with Flowmaster mufflers. Not done with this one yet.
Next is a '70 Nova that is getting a 383 stroker, Vortec heads, Voodoo Cam, Air Gap, 750 holley double pumper, some MSD. Behind that is a Borg Warner T-10. This one isn't done either.
I also have a '60 BelAir 4 door. It currently has the orig 283 and powerglide. I originally was to install a 350 and 4L60 with TPI and a Vortech supercharger. It was a plan to be a sleeper. But I have really gotten into the Ratrods, so I want to build this into sorta a Ratrod. I have gotten alot of ideas and ways to go with this one. I can't wait to start on this one.
See yall around.
Old 10-02-2007, 06:49 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
re: hey yall
Hi ya Brian...Welcome to Hotrodders.
Old 01-27-2008, 08:28 AM
BGB30 BGB30 is offline
Old Iron Head
re: hey yall
i wish my wife would let me have that many projects at once lol i would be in heaven... i love the 87 t-top monte you got... i got a 78 t-top monte witch is a work in progress.. but its sounds like yours is still going to walk all over mine when im done... close to the same set up but mine is not a stroker... just the good old 350 ...
Old 01-27-2008, 11:05 AM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Build them like you like them
re: hey yall
Welcome aboard!!
Old 01-27-2008, 01:41 PM
Job~Rated's Avatar
Job~Rated Job~Rated is offline
Artful Dodger
re: hey yall
Welcome, Brian!
Old 01-28-2008, 05:11 PM
schnitz's Avatar
schnitz schnitz is offline
I fixed it until it broke....
 schnitz's barnstar
Wiki Edits: 43
re: hey yall
The OP has been offline for nearly a month, and this intro was posted almost 3 months prior. I'm thinking either Brian is stuck really bad, or else his wife "discovered" his projects....Brian, if you check back in anytime soon, we need to discuss joint custody of the Monte's.
In a while, Chet.
It's not what you take with you when you leave, it's what you leave behind you when you go.
Old 01-29-2008, 05:03 PM
still here
Hey yall, I am still here and kickin'. I have been working out some bugs with the burg Monte and driving the mess outa it. Man that thing has some power. I might just scare myself one day.
Don't have to worry about a wife makin a discovery, ain't got one, don't know if thats good or not??
See ya'll around.
Old 01-30-2008, 09:50 AM
schnitz's Avatar
 schnitz's barnstar
Wiki Edits: 43
re: hey yall
See ya'll around.
If you aren't scared yet, you aren't trying hard enough...
So, what do you say about the joint custody? I'll be really nice and let you have them Sunday night through Friday at 7 am....
In a while, Chet.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "hey yall"
hey, y'all lenny g Introduce Yourself 2 05-31-2007 10:35 PM
Howdy yall MuscleCarKid_1991 Introduce Yourself 1 05-11-2007 12:20 PM
hey yall lightemup Introduce Yourself 4 03-28-2007 09:29 PM
Hey Ya'll BigBlockBabe Hotrodders' Lounge 5 11-24-2004 03:58 PM
hey yall csaroaddevil Hotrodders' Lounge 3 11-13-2002 12:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
