Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hey you sandblaster guys...
Old 01-30-2013, 05:28 PM
oldred oldred is offline
Not sure which Quincy model you have but from your description it would have over 15 CFM (that's an honest 15+ CFM, not an inflated figure like some of the cheapos) plus it will have a 100% duty cycle so I think it is certainly up to the task, you can run that Quincy all day without hurting it! The trick is to use a nozzle sized for the CFM available and in this case a 1/8" should be about right, you could use a 5/32" but it would require some waiting because of exceeding the compressor output but still not too bad to use.
And yes that Bellaire is a brute also! Darn good compressors for the money.
The Following User Says Thank You to oldred For This Useful Post:
NEW INTERIORS (01-30-2013)
