Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HF 97503 Dual MIG Welder $149.99
Old 01-08-2010, 11:10 PM
matt167 matt167 is offline
Wiki Edits: 31
mine was a flux wire. but they all use the same feeders and gun setups.. polarity is only switched for flux or gas welding, so the welder was wired for DC- permenently.. my new machine is easilly switched tho and the HF Mig... I buy a lot of stuff from HF so I'm in no way against them but after buying that paper weight.. I would have to say in this case. one mans junk is another mans junk.... it was only good for spot weld because the feed wasn't consistant enough to maintain a solid arc
there non serviceable also. once somthing happens to the gun or hose, the machine is garbage
