-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   HF Cart (http://www.hotrodders.com/forum/hf-cart-197627.html)
Mr.NutCase 05-01-2011 11:39 AM
HF Cart
I have seen a car mag that has HF coupons that has this cart for $49 buck
http://www.harborfreight.com/large-s...wer-90428.html
Is this a good deal?
cjperotti 05-01-2011 01:39 PM
I have one of those. It,s three years old and still serving me.
tech69 05-01-2011 03:56 PM
Not a bad deal. Harbor freight has it's place and for that purchase I give a nod. I got their welding cart and although it doesn't fit perfectly and I can't open the side door I can just put a piece of wood under and it will be perfect. It's for things like this that make HF my second best place for tools.
cal1320 05-02-2011 05:17 AM
I ve found the carts are even more useful by building a removable 3/4'' plywood top or counter top. The extra flat surface come in handy sometimes.
I think I made mine 24 x 36.
JohnnyK81 05-02-2011 09:25 AM
Depends.. Do you need a cart? If so it may be a good deal!
If you don't... Probably not.
:D
Runnin'OnEmpty 05-02-2011 08:42 PM
I have 2 HF service carts that serve very well.
Mine dosen't have the storage tray; but yes
that one is worth the money. You couldn't
build anything comparable for the money....
matts37chev 05-02-2011 09:09 PM
what will it be used for?
302 Z28 05-03-2011 09:13 AM
HF does have some decent stuff, case in point. I just received a vibratory cleaner I ordered from HF. I am going to use it to clean fired pistol cases for reloading. It is identical in every aspect to the ones sold by both Brownells and Midway for upwards of $79. HF had it on for $49 and I had a $10 off coupon. I have used it several times since receiving it and it works great.
Vince
