HF MIG-100 wire feed
4-5 years ago I bought an HF MIG-100 wire feed ( flux core ) welder, it never fed quite right ( jumpy ) and eventully the feeder stopped working, when the rubber wheels wore a groove... I got a new redesigned feeder under warranty from HF and installed it a couple years ago, never bothered to see if it worked, never put the spool back in, cause I didn't think it would work better than it did.... fastforward to yesterday when I had to weld somthing and I don't have the arc welder anymore ( at our other house ).. so I got the welder out, put the spool in it, and went welding.. and it now feeds really smooth, welds decent too.. I was welding 1/8"x1/4" angle iron, and it did take a bit to get it hot, but it worked..
then I practiced on some sheet metal, and I can't run a bead without burning thru, but I can spot it togther.. |
What was the re-design on the feeder out of curiosity? |
the tensioner on the old 1 used a flat bar with a thumb screw for tensioning, the flat bar ran to the non powered feed wheel, and it didn't tension well.. new tensioner connects the feed wheel with a thumb screw more directly.. works much better.
| Recent Garage - Tools posts with photos |
| question about ballast resistor and wire gauge | redneckprofessor | Electrical | 25 | 06-09-2007 01:50 PM |
| GM Alt Singe wire to three wire | streetrodderdoug | Electrical | 10 | 05-26-2007 05:23 PM |
| wire feed vs mig | newcustom | Body - Exterior | 10 | 08-04-2003 08:30 AM |
| One wire or three wire? | Screwy Lewy | Electrical | 0 | 06-30-2003 04:33 PM |
| 57 Chevy generator to altenator swap | Rodrunner | Electrical | 2 | 07-17-2002 09:59 PM |
