HF paint guns - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2007, 01:05 PM
HF paint guns
I have the HF 90977 and 46719 detail gun. For those familar with these guns, what dynamic pressures do you guys use?
Old 01-10-2007, 07:27 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
I have the same question for the 43430 gun.
Need suggested pressures for
Urethane
Base
Clear
Primer
Because, everytime I use it and get a good pattern with good atomization, my pressure makes the gun shoot like the old style with LOTS of overspray.
Old 01-10-2007, 07:58 AM
tab's Avatar
tab tab is offline
The "suggested" pressures would be just a ball-park anyway. Do some tests before you shoot.
Old 01-10-2007, 08:34 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
2Long, Thats the nature of the purple gun. You'll need around 40-45 for it to spray right reguardless of "what" your shooting and that's "conventional' land.
Otherwise, You can back the pressure down but you'll end up with a smaller fan & pattern and have to go slower.
Another reason I switched to Iwata.
Old 01-10-2007, 10:26 AM
There's a website around that talks about setting up the purple gun... I'll check my archives. As I recall, I set mine to 30 - 35 psi inlet pressure with the trigger pulled all the way back and air flowing through the gun.
Old 01-10-2007, 11:13 AM
BIGSKY's Avatar
See project in Photo Album
Shooting PPG K36 build primer I am running 45 lbs. and this is at about 10% reduction. Same for my epoxy. If I don't reduce it shots like hell, but hey its a thirty dollar gun...
Don't know about settings for topcoat yet, shot one thing with my 2nd purple gun and it came ok just ok, need to do more setup.
Old 01-11-2007, 04:25 PM
Here's a web site that talks about setting up the HF purple gun: Link
Old 01-11-2007, 04:47 PM
BIGSKY's Avatar
Thanks! I am plan to paint the underside of my hood tonight, so this info is real helpful.
Paint guns 56chevys Body - Exterior 4 02-14-2007 08:32 PM
Used Paint Guns? cab Body - Exterior 6 05-08-2006 04:33 AM
HVLP Spray guns and paint viscosity: x711 Body - Exterior 21 11-15-2005 08:49 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
