Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is the HF press a decent shop press?
Old 05-02-2009, 06:04 PM
capta1n capta1n is offline
I bought one of these a couple years ago. It works ok. Nothing special about it. But has saved me lots of time when I have been in a pinch. My only real complaint about it would be the bolts a loose in the holes. When you put some pressure on a part the unit has a tendency to lean to the right. Adding an X to the back of the frame with some some cable or strap will help prevent this movement.
Good luck. j.L>
