HF Purple Gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 04:27 AM
adtkart@aol.com
HF Purple Gun
Has anyone else had problems with the paint cap fitting on the cup of the HF purple gun? With mine, it appears that the lip of the cap is rolled in, and it won't screw on. I guess I need to find another cup that will fit the gun right. I really don't like the plastic cups with the screw on caps. If someone knows of a metal cup with a push on lid, that would help tremendously.
Aaron
Old 02-20-2006, 05:16 AM
302 Z28's Avatar
You can buy a larger aluminum cup with a snap on lid from The TuulShed. I have not had any problem with my plastic cups.
http://stores.channeladvisor.com/the...KU=RP827/1000M
Vince
Old 02-20-2006, 07:01 AM
cboy's Avatar
Last journal entry: Finished
No problem...other than the time I forgot to put the cap on altogether. You can imagine what a mess that was when I tilted the gun over. (I'm gettin' too old for this stuff.)
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 02-20-2006, 07:20 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Harbor sell's an alum cup at the store for this gun. It's the gravity feed HVLP cup by the gun section.Only gravity cup they sell as far as I know.
Couple of things.
Open the box and inspect the inside of the cup. Some are finished a LOT smoother than others,so get the best one. I opened 4 and got the best of the lot.
IF you soak the rubber cap in solvent much,it will shrink and not fit anymore.
I have 2 that the lids don't fit anymore,The purple & Iwata both did this.
I actually switched both my metal cups back to the plastic and use the DeVilbliss bag adapter kit now. The adapters will not fit the metal cups but work great in the plastic one's.It's SOOOO much easier to clean with the bag as all you need is a little thinner for the fluid area inside the gun instead of having to clean the whole cup & gun.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
