-   -   hf purple gun (http://www.hotrodders.com/forum/hf-purple-gun-87283.html)
hillbillly 04-19-2006 01:40 AM
hf purple gun
well thought id go ahead join been reading threaads here for a week or so and seems like some really good info.anyhow i been reading on how good yall like this hf gun,and just got the new hf flyer today and there runnin a special on it i figured id pass on.lot#47016 $12.99 good till 5/15 i hate going in that store,ill go in to get a couple things and come out with a dang buggy full.lol most of the time decent qualiy for the money.have went threw like 4 of there plastic welders but they never need a receipt or give me a fuss.got the extended warranty on it last time and wouldnt you know finnaly got a good one has out lasted others like 10 uses now.
redsdad 04-19-2006 06:03 AM
That purple gun is not an HVLP. I think the one everyone likes is # 43430-8VGA. It's on sale for $39.99.
cboy 04-19-2006 06:36 AM
My HF HVLP is also purple...so maybe they've got more than one purple gun now. Best to go by the item number like redsdad suggests.
S10xGN 04-20-2006 06:25 PM
Just about all their guns are purple, I've seen at least 8 different part numbers with all different prices. Couldn't begin to tell them apart by looking. I do know that you can get a couple of different tips for the 43430 gun. It comes with a 1.8, I was able to buy a 1.4 and a 2.0 for it.
Russ
oldred 04-20-2006 07:23 PM
S10, Are you sure about that tip size? I bought two of those things some time back and both came with a 1.4 tip
adtkart 04-20-2006 07:28 PM
Mine came with a 1.4 also.
Aaron
302 Z28 04-20-2006 08:33 PM
It normally comes with a 1.4mm nozzle set, perhaps someone changed it out and returned it. I did manage to get hold of a 2.2mm nozzle set for my 43430, but it was way too big for my use. I think you could spray house paint straight from the can through that 2.2mm tip.
Vince
OneMoreTime 04-20-2006 09:12 PM
Hosers
Vince
Those tips are used for the spraying of heavy stuff like some of the body fillers that are sprayable..Gel coats in fiberglass and glass resins when laminating..
They do have a place in the shop for that sort of thing..
Sam
adtkart 04-21-2006 03:23 AM
Sam, Knowing how big the hole is in my primer gun with a 2.0, I figured a 2.2 was for spraying regular "Bondo" type filler, or mabe old undercoating. LOL
I don't do house paint!
Aaron
oldred 04-21-2006 06:33 AM
While on this subject, have any of you guys sprayed Evercoat's G2 with this gun using a 1.8 tip? What is the best tip size for that stuff with any HVLP gun? Since my old Devillbiss HVLP (1.6 tip) died all I have is guns with the 1.4 tip which simply don't work with something this heavy. The 1.6 was too small although I could use it but now I am going to get new tips for these HF guns for primers and I am open to suggestions.
302 Z28 04-21-2006 10:40 AM
I am using a 1.8mm nozzle to spray Omni MX241 which is fairly heavy bodied and it does just fine.
Vince
S10xGN 04-22-2006 05:05 PM
Hmm, maybe it was a 1.4... I know I got one smaller and one larger just in case.
Russ
