hf purple gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 01:40 AM
hf purple gun
well thought id go ahead join been reading threaads here for a week or so and seems like some really good info.anyhow i been reading on how good yall like this hf gun,and just got the new hf flyer today and there runnin a special on it i figured id pass on.lot#47016 $12.99 good till 5/15 i hate going in that store,ill go in to get a couple things and come out with a dang buggy full.lol most of the time decent qualiy for the money.have went threw like 4 of there plastic welders but they never need a receipt or give me a fuss.got the extended warranty on it last time and wouldnt you know finnaly got a good one has out lasted others like 10 uses now.
Old 04-19-2006, 06:03 AM
Will I ever get it done?
Last journal entry: Hood
That purple gun is not an HVLP. I think the one everyone likes is # 43430-8VGA. It's on sale for $39.99.
Old 04-19-2006, 06:36 AM
cboy's Avatar
Last journal entry: Finished
My HF HVLP is also purple...so maybe they've got more than one purple gun now. Best to go by the item number like redsdad suggests.
Always learning...and sharing what I've learned.
Old 04-20-2006, 06:25 PM
S10xGN's Avatar
Gotta love a turbo!
Just about all their guns are purple, I've seen at least 8 different part numbers with all different prices. Couldn't begin to tell them apart by looking. I do know that you can get a couple of different tips for the 43430 gun. It comes with a 1.8, I was able to buy a 1.4 and a 2.0 for it.
Russ
Old 04-20-2006, 07:23 PM
S10, Are you sure about that tip size? I bought two of those things some time back and both came with a 1.4 tip
Old 04-20-2006, 07:28 PM
adtkart@aol.com
Mine came with a 1.4 also.
Aaron
Old 04-20-2006, 08:33 PM
302 Z28's Avatar
It normally comes with a 1.4mm nozzle set, perhaps someone changed it out and returned it. I did manage to get hold of a 2.2mm nozzle set for my 43430, but it was way too big for my use. I think you could spray house paint straight from the can through that 2.2mm tip.
Vince
Old 04-20-2006, 09:12 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hosers
Vince
Those tips are used for the spraying of heavy stuff like some of the body fillers that are sprayable..Gel coats in fiberglass and glass resins when laminating..
They do have a place in the shop for that sort of thing..
Sam
Old 04-21-2006, 03:23 AM
adtkart@aol.com
Sam, Knowing how big the hole is in my primer gun with a 2.0, I figured a 2.2 was for spraying regular "Bondo" type filler, or mabe old undercoating. LOL
I don't do house paint!
Aaron
Old 04-21-2006, 06:33 AM
While on this subject, have any of you guys sprayed Evercoat's G2 with this gun using a 1.8 tip? What is the best tip size for that stuff with any HVLP gun? Since my old Devillbiss HVLP (1.6 tip) died all I have is guns with the 1.4 tip which simply don't work with something this heavy. The 1.6 was too small although I could use it but now I am going to get new tips for these HF guns for primers and I am open to suggestions.
Old 04-21-2006, 10:40 AM
302 Z28's Avatar
I am using a 1.8mm nozzle to spray Omni MX241 which is fairly heavy bodied and it does just fine.
Vince
Old 04-22-2006, 05:05 PM
S10xGN's Avatar
Gotta love a turbo!
Hmm, maybe it was a 1.4... I know I got one smaller and one larger just in case.
Russ
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
HF Purple Gun adtkart Body - Exterior 3 02-20-2006 07:20 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
