I got one of the small 20 -25 LBS HF pressure pot,, works fine,, use playground sand from Lowes,, found that that dryness of the sand is most important. I dry the sand that I use in the oven,, use turkey cooking size aluminum pans, roast at 275 for 30 minutes or so,, use a large fork to run throgh it to turn it over,,,,You will know when the sand is dry,, it flows real nice.
