hi all...Ford engine
i have a question,i just bought a ford block with all the top end ,(crank,rods,pistons)are missing. the valve covers ,and heads say Cobra La mans what engine would it be 427,or 428
Sorry, I do not have my Ford books available, I am working off memory.
First, bore sizes. 4.050 could be a 360, 390, or a 410. The crank for the above engines has a stroke of about 3.5, 3.78, or 3.98. The next standard bore size is 4.130, I think. With the 3.78 crank, you get a 406. The 3.98 crank gives you a 428. The 427 block has a bore of 4.230, I think. Used with the 3.78 crank, you get a 427. Some 406 and 427 blocks had cross bolted main caps on 2, 3, 4 main caps. Some of these blocks also had provisions for a direct oil passage to the crankshaft, and were called side oilers blocks. And if you get really lucky, you may come across a 427 OHC FE Ford block. |
There was also the 332 (never seen one) and 352 (fairly common in the early 60's) FE engines.
Bruce |
I saw a 332 once. It was in a sickle bar swather. For cutting hay. It had a 14 foot bar on it, and it could mow.
Fact is stranger than Fiction |
ford FE
well i found out from Ford the engine is a 1967 or 68 shelby cobra 428,thanks all
I'm no FE expert but FE's are tough to ID since Ford used one casting # for several different size blocks...352/360/390/406 and 428 IIRC. The only way to confirm what you have is to measure the bore and stroke.
the heads have brass tags on them the intake is a ford aluminum,the bore is right and the valve covers are ford factory and all numbers match.the head tags say it`s a shelby cobra gt500 so i`ll be buying crank rods and pistons for whatever,the bore job turns out to be,going into a 1969 f100.
| Tags |
| engine identification, ford |
| 1948 Ford stock engine/tranny with Ford 9" rear end | beek15853 | Transmission - Rearend | 5 | 04-04-2012 07:56 PM |
| 1936 ford V8 engine & transmission in 1931 ford | JB1931 | Hotrodding Basics | 3 | 01-22-2012 10:05 AM |
| 1934 Ford transmission with1948 Ford truck engine clutch questions | ppetrano | Transmission - Rearend | 1 | 05-20-2011 11:02 AM |
| Need advise on Ford 300 engine swap to a Ford 400 | aztek_warrior | Hotrodding Basics | 6 | 03-22-2011 02:59 PM |
| Ford 302 engine to engine stand bolt size? | Lee in Texas | Engine | 4 | 03-24-2008 10:30 AM |
