Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hi Build Primers VS 2 part epoxies?
Old 07-09-2005, 04:40 PM
67goat 67goat is offline
Epoxy Is What You Want To Start With, Then The 2k Primer , It Is A 2 Component Urethane Primer, Also Called Hi Build Or 2k Primer, Some High Build Has Capabilities Of Filling 80 Grit Scratches Easy, I Have Even Used Some Over 40 Grit Scratches Test Patterns, Three To Foar Coats Let Dry Overnight Guide Coat And Start Blocking, Hope This Helps.mike.
