Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hi, engine light on
Old 02-21-2012, 07:17 PM
rsfyj rsfyj is offline
Last journal entry: My Last Hot Rod
Hi, engine light on
I have a 2002 Ford Windstar van. The engine lite stays on since I ran the battery down and replaced it. I went through this one time before. It said gas cap not tight. The computer needed to see gas fill ups 4 or 5 times at different levels and run for at least 400 miles. Then the computer would get new data and the light went out. I have done all that once again and I also got a new gas cap, checked my pvc, and looked for any lose hoses but the light stays on this time. I cant get a inspection sticker here in mass to run on the roads if the light dont go out. I need some of you Hi tech Car guys to tell me where to look next. Taking it to a Ford garge is a waste most will screw you on the spot. I know from past engagements. They will hook up a computer and tell you to replace this, this and this and after 500 dollars the light is still on. Any help from guys who have had this problem will be greatly appreciated.
