-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   hi!!i am looking for schematic tig-welder (http://www.hotrodders.com/forum/hi-i-am-looking-schematic-tig-welder-159207.html)
velosiped 05-28-2009 02:42 PM
hi!!! has anyone successfully made a tig welder from a dc/ac welder
oldschoolrods 05-28-2009 08:31 PM
Hello. It can be done and will work but generally it doesn't work real great. You didn't specify what power source you have so here are a few things to consider. You're going to need a high frequency unit if you plan on doing aluminum, (and to make your life easier on steel) but if your machine doesn't have a provision for a remote that is going to make aluminum almost impossible. If you just want to set it up for steel, all you really need is a Torch with a manual gas valve, and a bottle of Pure Argon, and the proper connectors. You would have to do a scratch start, but it would work just not the greatest. If you could please post what kind of machine you have, I can probably help you out better. Hope that helps.
velosiped 05-29-2009 01:27 PM
Hi i am looking for schematik tig-welder
Hello.thank you for answer.i would be pleased made homemade tig-welder.actualy i have simple homemade ac/dc welder as power sourse i am used 220 volts.i have not any remote control for welder.what can i do to built a homemade tig-welder ?thank you.
velosiped 05-29-2009 01:28 PM
hi i am looking for schematik tig-welder
