hi!!i am looking for schematic tig-welder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2009, 02:42 PM
hi!!! has anyone successfully made a tig welder from a dc/ac welder
Old 05-28-2009, 08:31 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Hello. It can be done and will work but generally it doesn't work real great. You didn't specify what power source you have so here are a few things to consider. You're going to need a high frequency unit if you plan on doing aluminum, (and to make your life easier on steel) but if your machine doesn't have a provision for a remote that is going to make aluminum almost impossible. If you just want to set it up for steel, all you really need is a Torch with a manual gas valve, and a bottle of Pure Argon, and the proper connectors. You would have to do a scratch start, but it would work just not the greatest. If you could please post what kind of machine you have, I can probably help you out better. Hope that helps.
Old 05-29-2009, 01:27 PM
Hi i am looking for schematik tig-welder
Hello.thank you for answer.i would be pleased made homemade tig-welder.actualy i have simple homemade ac/dc welder as power sourse i am used 220 volts.i have not any remote control for welder.what can i do to built a homemade tig-welder ?thank you.
Old 05-29-2009, 01:28 PM
hi i am looking for schematik tig-welder
Good quality TIG welder which one?? sevt_chevelle Body - Exterior 11 01-13-2015 11:39 AM
TIG Welder jlandell Introduce Yourself 4 01-30-2007 01:38 AM
My DIY tig welder.. Travis Rankin Garage - Tools 134 11-20-2006 02:56 AM
Hook Up Lincoln Square Wave Tig 175 Pro Welder ONEGALONLY Garage - Tools 3 03-15-2006 08:30 AM
Seeking used TIG welder rpaulsen Body - Exterior 3 02-04-2004 12:19 AM
