hi i am new yes i am a female - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 07:45 PM
i had my distributor replaced and now my car seems like it struggles to start could that have something to do with the distributor.
Old 12-30-2011, 10:04 PM
471A
Welcome ! To get a useful answer from the experts on this site, more info is needed. What is the year, make, and model of the car and what is the engine in that car and does it uses carburetors or fuel injection ?
Old 12-31-2011, 07:49 AM
cool rockin daddy's Avatar
Marie,
Chances are the timing is either retarded or too far advanced. Who replaced the distributor?
Last journal entry: update
More info will help us get your problem sorted out,
BUT
To answer the question, YES, the hard starting can be caused by the wrong setting.
Distributors are held with a clamp. Loosening the bolt holding the clamp allows you to turn the distributor. We sometimes call it a dizzy for brevity.
Turning the dizzy affects the exact timing of when the spark plugs fire.
Setting the timing is very easy. It requires a distributor wrench, and a timing light, you can get both from Harbor Freight for $30.
The exact procedure depends on what you have, but there is the other option.
Try-it-and-see. Basically, loosen the clamp, turn the dizzy a hair clockwise, snug the clamp, then try to start the engine. If it's worse, try it 2 hairs the other direction.
Once it is started, shut it off and mark where you started. White-out or a sharpie can work. Then re-start it, and you can wear an insulated leather glove, and turn the dizzy to the highest idle speed. Snug the clamp there, shut it off, make a second mark, then try to re-start. If it is again difficult, then at least you know the ideal range is somewhere between your marks.
female car freak lilmissbhaven Introduce Yourself 6 09-04-2011 11:55 AM
Female Street Rodder Fran Introduce Yourself 5 08-02-2009 04:10 PM
female dragracer twowild37 Introduce Yourself 2 02-04-2008 01:36 AM
From a female customer Sandflea427SS Hotrodders' Lounge 35 08-19-2004 03:25 PM
Attention all female members. Halloweenking Hotrodders' Lounge 65 12-07-2002 01:18 AM
