Hi/ need cam specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 05:28 PM
Hi
hello just joined trying to find out grind specs for a crane cam cd10007b
Old 09-07-2009, 06:25 PM
life is a temporary assignment
Welcome to the site... Glade to have you here...
You will get a better respond in the engine section..
Old 09-07-2009, 06:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. ,,,,,,,,,,,,,,,,,,,Cole
Old 09-07-2009, 09:20 PM
techinspector1's Avatar
Wiki Edits: 326
Don't know about the cd part of it, but 10007b could have been the predecessor to 100072. 0.480"/0.480", 284/284, 228/228, 112 LSA. Intake closes 41 ABDC @ 0.050" tappet lift. Use with 9.5:1 to 11.0:1 static compression ratio. Operating range 2800-6200.
Don't make any decisions based on what I have posted here. Your cam may not be the same one. If you didn't pull it out of a motor and keep the lifters in the same bores and plan to use the cam back in the same block, it's junk anyway.
Old 09-07-2009, 09:27 PM
Putting in a differant motor with new lifters the CD I read a post on here is for Cam Dynamics Cam Dynamics Catalog I know I need to replace my springs this motor has ate 3 cams I trying to get the specs so I know what springs to buy
Old 09-07-2009, 09:39 PM
Wiki Edits: 326
My best advice would be to purchase a new cam kit from Summit so that you are certain what you're dealing with, but I'll try to help with what you have.
What's the diameter of the spring pockets in the heads?
Also, using your dial caliper, measure the cam lobes from heel to nose (largest measurement) and also from side to side and deduct. For instance, if the larger measurement was 1.320" and the smaller was 1.000", then deducting would yield a cam lobe lift of 0.320". Multiplying that by a rocker ratio of 1.5 would yield a valve lift of 0.480".
