Hi! New Member with a question. - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 09-03-2002, 07:43 AM
Post Hi! New Member with a question.
Hi! I'm a new member to this board and enjoy reading the topics and posts very much. I have a '93 GMC Sierra SLE regular cab short bed pickup with a 5.7L and R700-4 auto. I have installed a Hypertech Thermomaster chip, 160 degree thermostat, Hypertech power pulleys, Hypertech free flow air filter, Accel super coil, 1" tbi spacer, and removed the air cleaner silencer and replaced it with a straight flex tube to the inner fender well. Also the truck has a 3.73 posi rearend. After installing these items, I had a noticable increase in power. The only problem is that from a dead stop, in low gear, when I floor the pedal, the truck falls on its face like it isn't either getting any fuel or totally flooding out. Then after this initial hesitation, it kicks in great and leaves hard. The truck has over 100k miles on it. Could it be my timing chain has slack and is throwing my timing off a bit? Also, would the tbi vortec intake that GM Perf. Parts sells and a set of Vortec heads really help my performance? If so, would I need a different chip?
Quick reply to this message
Old 09-03-2002, 08:13 AM
4 Jaw Chuck's Avatar
Post
I would try dialing in your throttle position sensor first, sometimes they can be out significantly which throws off the mixture. I don't have a link just for Chevy's describing the procedure but it is a common problem on all cars. Basically you slot the mounting screw holes and use an ohmmeter to get the correct reading for idle speed. I have never done it on a Chevy but all the Fords I have done sure fixed a lot of problems I had assumed were vacuum leak related or computer caused.
Have you tried your factory chip? Most of those aftermarket chips don't work too well in my experience except on the dyno. Of course this is all assuming there is nothing wrong mechanically with the car like leaks, dirty idle air bypass port, throttle plate carbon buildup, ignition failure locking the timing, codes on the computer, dirty air filter, clogged fuel filter, dirty spark plugs, stuck open EGR etc. etc. etc. Make sure you check all those things before you condemn anything expensive.
— Han Solo
Old 05-02-2015, 01:18 AM
I'm with Chuck.
I'd say try your stock chip and then see if you are getting the spark you need at low end.
If it's a stock motor, it doesn't want to run at 160 - you'll carbon up the heads.
Old 05-02-2015, 04:33 AM
poncho62's Avatar
Wiki Edits: 5
13 year old thread?
Old 05-02-2015, 09:01 AM
Yeah, that's pretty funny.
I get a notification by email that someone has just posted to a thread I follow and I reply to it only to discover that the post is 13 years old.
How about tweaking the forum so that only replies posted AFTER mine are sent to me as new posts? Or maybe I shouldn't get any notifications at all.
Old 05-02-2015, 09:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Read the dates of the threads when you are searching the forums.
You can adjust your setting in the profile so there are no notices sent on new messages.
Old 05-02-2015, 09:59 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
How did you get a notification someone has posted to this "thread you follow" when you're the first poster since 2002, and you joined two days ago?
Semper Fi
Closed Thread
