Hi output alternator install - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2009, 11:51 AM
I purchased a one wire World Power Systems 160A alternator and would like to install it on my '91 Camaro. It has the 3 wire connecter, two prong receptical covered on the top of the unit. It is my understanding this 2 prong connector only provides the idiot light indication and not the voltage reading on the gauge. Is this accurate? I also understand I need to upgrade the feed wire from the alternator to the battery to an 8 gage or maybe a 6 gage with the 160A output.
Any info would be appreciated.
Thanks,
Roy
Old 06-15-2009, 09:32 PM
fast68's Avatar
likes chevy trucks & boobies
actually the bigger wire to that connector goes to battery as well as the charging post wire on the back of the alt
use same guage as the existing wires
14 or 12 guage
the smallest wire is to the guage or light
700r4 output shafts stuvand Transmission - Rearend 2 05-15-2008 07:12 PM
TH350 output shaft Nalehed Transmission - Rearend 3 06-07-2007 08:11 PM
Should Output Shaft Wiggle on THM200 4R? JohnTN Transmission - Rearend 20 11-15-2006 10:32 AM
Different size output shaft on c4? nitrous_69stang Transmission - Rearend 3 04-17-2006 11:51 AM
Power output formulas SAATR General Rodding Tech 14 05-12-2004 09:46 PM
