hi-temp manifold - header paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 09:44 PM
is there any brand of hi temp paint that has proven superior in use on manifolds and or headers?
would like to go with ceramic,, but is the price differential worth it?
Old 04-06-2011, 12:08 AM
techinspector1's Avatar
Wiki Edits: 326
This question cam up the other day and Eric gave this reply...
"A low cost method that works for a couple years is to sandblast them clean, and paint with genuine John Deere Muffler paint. The Deere paint works better than any I have tried in the high heat department. Very light coat, just enough to turn them black. Thick coats will peel when heated."
Old 04-06-2011, 10:00 AM
interesting, I have a friend that has a body shop,, he says John Deere black is the best underbody - frame rust proofing paint there is,, says by comparison to other special rust proofing paints,, a lot less expensive.
Old 04-06-2011, 01:54 PM
High temp paint
Look into a company called Techline. The are the suppliers for a lot of companys that do ceramic coatings. They do sell their products to the general public. They also sell some other interesting stuff. I also bought their high temp self curing aluminum colored coating.
Old 04-07-2011, 12:02 AM
Heat coatings
Our fire dept. contacted John Deere several years ago to try to contract with them to mix some of the red color we use for our under carriage protections. They did it a like you've been told in this forum it is a very good product. Not cheap but very good. Prep of the surface to be painted has to be done carefully and meticulously too.
Normbc9
Old 04-08-2011, 11:36 AM
rusty87
thanks, I looked at the tech line web site and then did a internet search for comments on the tech line exhaust system coatings.. Got hits on lots of forums, from F bodies to subaru to honda to arctic cat.. saw one negative posting that the paint disappeared from the headers in a month,, but that poster also said he put it on really thin, saw lots of posters saying they have had good success with home applications,, one guy said he had it on a manifold for over a year and it is holding up fine. most agreed the surface prep is critical. How soon are you going to try the tech line coating? I have blasting pressure pot and a spray paint set up,, so I'll likely give this stuff a try,, will be late may or june
Old 04-08-2011, 04:00 PM
High temp paint
DadTruck, You'll probably do it before I do. Stuff keeps coming up. I just finished putting control arm bushings and ball joints on the Jimmy. Preparation for the application of the paint is stressed as critical as you said. I am waiting for some one to donate an oven for the cure. (not likely) But it is not required for all their products. I'm glad you found the stuff interesting. They have very good customer service too.
Old 04-10-2011, 08:37 PM
el pollo's Avatar
It's shady under this tree...
Not only is the prep crucial, but so is the heat cycle. All high temp paints require a heat cycle process for it to fully cure.
Temp Sensor for manifold STUDE55DOG Engine 3 08-11-2009 02:24 PM
Header temp redneckhotrods Engine 12 12-19-2008 07:13 PM
temp sensor on blower manifold Kilrcady Engine 16 05-26-2008 10:22 AM
What is the typical manifold temp... STATUTORY GRAPE Engine 8 04-03-2007 07:06 PM
Change colour high temp header / turbo paint? Sycloned Body - Exterior 1 08-03-2003 10:08 PM
