HID headlight conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 11:24 AM
scrot's Avatar
Does anybody have an opinion on HID headlight conversions?
They cost only $80, is simple to install, and shine 3X the light.
Sounds good to me. To install all you have to do is enlarge the headlight bulb opening to 25mm, install the new HID bulb, and hook up the ballast and wiring.
Old 04-10-2011, 01:07 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I checked around and they dont do well at all for a retrofit. I was looking at the same thing and I found they are being outlawed.
They dont throw a proper shaped beam of light and the light it does throw is very glaring and diffused as the housing is designed for a bulb with a different shape of illuminescense.
The NHTSA is outlawing them all over.
The best (or at least one of the better) options is to put in silverstar halogens. I use them and they are pretty decent.The ones in my truck have lasted 5 years allready. For some reason the ones in the camry last about a year. Not too pleased about that. Keep the reciept and the warranty card.
Old 04-10-2011, 01:22 PM
Irelands child's Avatar
You must have the only good set ever made for longevity!! The Ford Forum has less then great words for them. I've used them in the past in my trucks and cars and they seem to "die" about a month after the one year warranty runs out. I use the ExtraVision now - and they are bright in all three vehicles (including the '31) and seem to survive for years.
The HID systems interesting - and here is a link you might want to read: http://www.danielsternlighting.com/t...nversions.html
Old 04-10-2011, 01:56 PM
LATECH's Avatar
Extravision.....Hummmmmmm. Gonna have to look for a set. Thank you IC.
Old 04-10-2011, 02:43 PM
I blew it on spelling - s/b Xtravision (http://www.sylvania.com/ConsumerProd...ce/Xtravision/)
Dave W
Old 04-10-2011, 05:46 PM
sqzbox's Avatar
My pipes are my music
Their only good for the guy driving AFA I'm concerned. Too dang bright and all the different colors? pink, green, blue, It's getting crazy out there anymore. Good targets for BB guns!
Old 04-11-2011, 12:06 AM
Wiki Edits: 31
most people use DDM tuning HID kits cause there dirt cheap.. The problem with retrofitted HID's is, most do not bother with the correct projector housing. HID's without the projector housing is illegal.. Without the projector housing, the light isn't projected forward correctly, and it blinds oncomming drivers...
I'm the kind of guy that feels they are a waste of money.. I run low beams 90% of the time.
When it comes to headlight temp colors
3,500k is stock
4,000K is white ( silverstar, phillips and many others manufacture them )
5,000K is light blue
6,000k is dark blue
8,000k is purpleish
9,000K plus goes red
Old 04-11-2011, 07:22 AM
sqzbox's Avatar
3,500k is stock
6,000k is dark blue
8,000k is purpleish
Above 4,000 will blind old pharts like me!
Old 04-11-2011, 05:24 PM
scrot's Avatar
This rates just the color of the light, not the brightness.
That article mentioned above certainly is against HID conversion lights. It sounds like the author has an agenda to stop the conversions.
Old 04-11-2011, 06:35 PM
If you are talking about the Daniel Stern link, he wants to stop the non-DOT approved junk from proliferating
Old 04-12-2011, 03:28 AM
sqzbox's Avatar
I believe you forgot green.
Headlight conversion question. Rodillac Electrical 19 07-03-2010 09:31 AM
'39 chevy headlight conversion? RodFather General Rodding Tech 4 07-07-2005 01:50 PM
H4 headlight conversion Blackdog Electrical 1 03-04-2005 01:36 AM
HID Headlight conversion ffcagle34 Electrical 9 02-11-2005 12:38 AM
Headlight Conversion Wayne Electrical 3 11-26-2002 07:31 AM
