hidden gas filler behind plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2011, 11:13 AM
dirty dixon's Avatar
In my 54 chevy pickup I think I am going to put the gas tank under the bed.
I am thinking about installing a hidden fuel filler behind the plate in the roll pan. Any of you guys have any trick/tips to share. (ie. cars models to get some gear off of) Any pics or comments would help.
Old 03-25-2011, 11:43 AM
Last journal entry: Some More Roll Cage Fabrication
There are tons of cars, but my favorites are 68-79 Novas
Old 03-25-2011, 11:53 AM
malc's Avatar
Living At The Speed Of Life
2nd gen Camaros.
Old 03-25-2011, 01:38 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The 80s b-body's have them too.
Old 03-25-2011, 01:43 PM
35terraplane's Avatar
hidden gas filler
I know there are no dumb question, or not suppose to be, but, isn't the roll pan lower than the underside of the box bed. With this in mind how do you fill the tank. The only way I see it is you put the tank bottom even with the lower edge of the rolled pan, the filler would still only at best let you get 3/4 full. I might be missing something.
Bob
Old 03-25-2011, 01:44 PM
I just did roll pan for my truck with a hidden trailer hitch. Used a new Nova plate holder I got off Ebay. I think it was about $25 plus freight. Worked well.
Old 03-25-2011, 02:09 PM
hidden gas filler
A hidden trailer hitch is one thing a gas filler is another. Could you put a gas tank under your box, and a plate holder in your rolled pan, and the plate holder be higher than the tank so that you could put a gas door in it with filler tube.
Bob
Old 03-25-2011, 02:40 PM
1969 chevelles have the filler behind the plate. Not certain but the '68's prolly do as well.
Old 03-25-2011, 03:00 PM
hidden gas filler
But the plate is right below the trunk opening, which drops down into the trunk, you can see the filler tube right in the front of the trunk going into the tank, below the truck floor. What I'm asking is the rolled pan on a P/U higher than the bed of the P/U floor, I don't think so, therefore how do you get the gas into the tank. I very well might be wrong I'm just asking.
Like my 46 Ford Coupe, the tank is higher than a rolled pan would be, therefore you couldn't put a hidden gas filler tube in the pan.
Bob
Old 03-25-2011, 03:12 PM
Wiki Edits: 15
Yeah, there's always gravity to take into account Like Bob said, you have to mount the filler neck opening higher than the tank itself or you're just going to make a huge and likely dangerous mess.
Old 03-25-2011, 09:42 PM
Yeah you're right there Terraplane. I was just saying the hinged plate door worked for me.
Old 03-25-2011, 09:58 PM
hidden gas filler
Good idea, is yours removable then? Would work better than trying to fill a gas tank from the bottom.
Bob
Old 03-25-2011, 10:12 PM
Bob
I was thinking the same thing when I saw this thread.
Old 03-25-2011, 11:59 PM
life is a temporary assignment
WILL NOT WORK !!!!!
Old 03-26-2011, 01:26 PM
Your best bet if you want to hide the filler is put it on the floor of the bed.
Front motor plate without a mid-plate? Steam Roller Engine 13 12-13-2011 11:56 AM
Filler over epoxy or Epoxy over filler? Here is some good info satexasf150 Body - Exterior 78 10-16-2011 10:35 AM
Few questions on cam bolt locking plate plus retainer plate. eric32 Engine 1 05-04-2009 05:19 PM
hidden vin on frames Cool 59 Hotrodding Basics 8 06-08-2008 01:32 AM
Hidden Hinges Larry Tyner Body - Exterior 16 12-31-2007 11:10 AM
