Hiding an automatic shifter in plain sight - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2013, 01:46 PM
Ok guys; a little hotrodder knowledge is requested. One of my local guys who is getting up there in age and he recently fell and busted his hip. Sadly, its time for his T10 to leave the party. His friends (myself included) would like to get something together for him so when hes ready, he can drive the car. Hes really down about this. We have a T350, a T700r4, a factory 79 camaro cable op shifter for the T350 and a whole lotta manpower and pocket change to help the old man get back at it and not worry about his baby.
Its a 2.64 T10 with 3.55s in the back (I think), no console in a 65 nova.
He'd prefer not to put a console in it. We looked at a Unimatic shifter; but theres no reverse lockout functionality, and Im not sure Id manually shift it "briskly". I suppose he could go lokar, but that looks more street rod than hot rod.
Ideally It'd be robust and positive enough to manually shift it, but look like a Hurst comp plus
Anyone ever hide an automatic shifter in plain sight? I'd probably mount the clutch pedal solid so he has a place to rest his foot.
Thoughts?
PS I googled it and have never seen so many "how-to's" on removing shiftknobs before. sad.
Old 08-09-2013, 02:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
My idea would be to take the shaft and knob from the old shifter and put it on the new shifter and then use a boot If you get my drift. Some of the shifters for autos use a gated system for the lockout. You may use the Lokar this way..I checked the B&M and it is a gated shifter so that may be an option for you..
Sam
Old 08-09-2013, 02:47 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
B&M makes a detent shifter . i used it here with a 200r4. we used the 4 speed console because it looks better than auto and we have 66 nova buckets. besides it's beautiful console.
Old 08-09-2013, 05:39 PM
dont know if anyone remembers but back a few years ago , a guy by the name of GARY BUCKLES ( if i remember right ) had a 70-73 Blue camaro , very custom for the time and was in all the magazines.
he had a automatic shifter that was hidded just under the dash on the right side of the steering column...IT WAS HIDDEN COMPLETELY and VERY COOL.
Old 08-10-2013, 06:20 AM
Irelands child's Avatar
Take a look at paddle shifters. Once you get an automatic in place, you can add one of those under the steering wheel. If he still wants 'the look' of a floor shift, you can probably make up a bracket and leave the original shifter in place. You would need an after market steering wheel adapter most likely, but then innovation IS part of the fun of hotrodding.
Street Auto
Dave W
Irelands child
Old 08-10-2013, 06:43 AM
Faith - Respect - Trust
X2 on the paddle shifter to solve the problem. I have recently had the opportunity to research one for a project I'm doing. I was bit intimidated at first but, now that I look at it, they are mostly plug and play. You will most likely need to change the steering wheel but, the one I'm installing came with adapter, electronics and everything needed for it to hook up to an automatic.
They are becoming more common place but would suite your needs perfectly.
Ray
Old 08-10-2013, 10:45 AM
302 Z28's Avatar
The Lokar shifter is not suited to fast shifting at all.
Vince
Old 08-18-2013, 09:08 PM
Semper Gumby
Wiki Edits: 2
Vince
X2!! I did a track oil down 100% due to that type of shifter! There is NOTHING to keep a 2-3 shift from becoming 2-N shift!
Old 08-18-2013, 09:50 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Street Auto
Dave W
Those are really sweet. The only downside is the price. 2K for a shifter? Yikes!
Old 08-19-2013, 02:17 AM
JeffB's Avatar
You could use this:Quicksilver | B&M Racing and Performance Products and delete the console and use the large boot since it mounts to the trans hump the stick is plenty long and you can always leave the clutch pedal just to "fool 'em"
T-Bucket automatic Shifter ? bobcat Transmission - Rearend 10 03-29-2006 03:14 PM
What automatic shifter is good novadan Transmission - Rearend 3 02-23-2006 11:45 PM
Automatic floor shifter appy_stables Transmission - Rearend 1 09-24-2003 05:00 PM
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 07:48 PM
Which Shifter for Automatic? Mr.56Chevy Transmission - Rearend 5 01-07-2003 07:59 PM
