High altitude carb size - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 07:39 PM
385 sbc
11.5:1 forged flat tops, dart pro 1 200's 2.02/1.6
solid roller (lunati 50169) .606/.587 248/252 @ .050 110 lsa
vic jr single plane
1 3/4 primary 3 1/2 collector headers
currently 750 dp.
at stop when you try to floor it, it dies. ive tried larger shooters jetting up and down. no carb shops locally. circle track guy says im too rich, doesnt seem right either. 4500' in salt lake city ut.
Old 05-14-2010, 03:30 AM
Last journal entry: A few ongoing projects
A bit more info would help, type of car, weight, transmission, convertor stall, rear end ratio and tire size.
Old 05-14-2010, 08:19 AM
Gutted 1981 El Camino probably 3000 lbs.
3000 stall th-400
moser engineering 8.5 10 bolt full spool 3.42
25 inch tall tire
Old 05-14-2010, 08:35 AM
speedfreak2's Avatar
WrenchingAce
Actually, if your engine dies when you hit the gas then you need to richen up the carb and/or put in larger squirters. Might want to check your timing first though.
Old 05-15-2010, 05:08 PM
Well i went and bought a pair of aftermarket o2 sensors and a narrow band gauge from IEQUUS. timing set to 16* idle at 1000 in park. at 200 degrees. I stepped into it hard and the A/R gauge went DEAD lean and died. 80 pri/ 86 sec .0625 primary squirter comes in instantly and 6.5 pv primary plugged secondary. Bigger carb?
Old 05-15-2010, 07:45 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by mistermisfit
I stepped into it hard and the A/R gauge went DEAD lean and died. Bigger carb?
You have determined that the problem is the ratio of fuel to air, not the quantity of fuel/air mixture delivered into the motor, so you don't need more carburetor, you need to fatten up the carb you have and pay attention to F-BIRD'88's tutorial about ignition timing and converter stall.
holley carb jet size to elevation ratio mazdaRx7 driver Engine 2 03-16-2010 10:26 AM
Edelbrock Carb Size for Stock Buick 455 youngceez Engine 38 03-05-2010 09:54 AM
Carb selection help SLR_65 Engine 2 09-03-2007 05:44 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
the right carb size??? pls help 59vette Engine 14 11-16-2003 09:31 AM
