High beam low beam relays - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-29-2010, 09:25 AM
BigRoy1978's Avatar
I used seperate powers for all of my lights.
I have three relays: Low beam, high beam, and one for my spots and floods.
That way if you have a short on the wire that goes to your low beams, and it blows the fuse, you can hit the dimmer switch and still have lights to get pulled over and fix the problem....
piggy back the powers from each, fuse blows you have NO power going to the relays, no lights....fill in your own tragic ending of choice!
my $.02
  #17 (permalink)
Old 12-29-2010, 03:19 PM
Wiki Edits: 49
I'm wiring my deuce as we speak. Two 30 amp relays for the headlights. Main power comes through a junction block and from there through separate fusible links to each relay. Low amp fused 12 volt power from the headlight switch runs to the dimmer switch which activates the relays.
Just take a look at the Mad Electrical web site for some very good tech on relays.
Centerline
HotRodsAndHemis.com
"Moonshiners put more time, energy, thought, and love into their cars than any racer ever will. Lose on the track, and you go home. Lose with a load of whiskey, and you go to jail." Junior Johnson
low beam/high beam cares Electrical 2 05-15-2008 07:23 PM
H-Beam vs. I-Beam Connecting Rods juiced66malibu Engine 2 10-26-2007 07:29 AM
high beam indecator light davedeltadog Electrical 4 12-06-2005 04:07 PM
help replacing the high beam switch saenz5 Electrical 2 10-06-2004 06:36 PM
High Beam Indicator Light wolfedog Electrical 4 02-22-2004 06:11 PM
