The answer is......it depends
If your vehicle is setup so that when you switch to High Beams, your Low Beam lights go out, then its OK to piggyback the power from relay to relay, because only one relay at a time is requiring power for the headlights. However, it you had four headlights, two low beam and two high beam, and both sets are "On" when you select the high beam switch, then I would have separate power wires to each relay as a safety measure. |
Now, it may be a good idea to run separate lines to each relay, or install a junction with 2 circuit breakers or fuses----1 for each relay. This would insure that if a fuse or breaker pops on one of the circuits----the other will still work. |
The optimum way would be to run separate fused power feeds to each relay. If one fuse blows for whatever reason you would still have access to lights, either lo or hi depending on which fuse is out.
Vince |
Mid to late 60's GM 4 headlight systems come to mind, they are 2 high/lows and 2 highs. I've had several friends have me wire dual relays, and they then switch to 4 lights both having high/low(dual filaments), they want even more light at night. |
I agree with Vince..
If the avatar pic is the vehicle..... seperate pwr feeds are redundant IMO ..... with a two light sys (hi-low) if the fuse/circuit popped and I'd want to sort out what made it short out and avoid possible meltdown.
Still----only ONE circuit at a time----Low or High----that is all the dimmer switch will allow-----as for more lighting on these, just upgrade to Halogen sealed beams---------anything more than that and it annoys oncoming traffic. I frankly don't care how far one wants to see at night, but if the ONLY thing I see is that bozo with lights brighter than the sun---it becomes an unsafe situation for everyone on the hiway. |
Just finished up installing the relays. Took a while because I routed the wiring nicely and made nice connections. I used the harness on the relays which made the job easier and neater as well. The relays work without any wires smoking... or fuses blowing
The lights appear to be about the same perhaps a little brighter than normal. I started my truck and the voltmeter went to 14.1 volts without the lights on. I turned the lights on and the voltmeter barely moved, maybe .2 volts if that . I also turned the high beams on and didn't get much more on voltage drop. Without the relays, my voltage with the lights on would drop to about 12.5- 13.0 volts. So I'm real happy I did this even though I'm only using sealed beam halogens, and definitely recommend to others using the relays. Thanks to everyone who provided me with a wiring diagram and info... |
This is the better way to have it.. I just did a Coupe that had One fuse running two relays.. Not good.. One was his Elect fan, And the other was for a elect motor to open and close his cowl vent.. Not good at all.. The wires was burnt when I took them out.. The fuse was burnt inside the fuse holder.. Now It's done right.. Good luck.. Last edited by NEW INTERIORS; 12-22-2010 at 04:10 PM. |
If you are referring to the relay wiring the only load that runs through both the headlamp switch and the dimmer switch is the coil or coils of the relay or relays. A typical 12 volt relay coil pulls about 300ma, two relay coils on at the same time would be 600ma, far less than if all headlamps were on and running though the headlamp switch and dimmer switch. Vince |
| low beam/high beam | cares | Electrical | 2 | 05-15-2008 07:23 PM |
| H-Beam vs. I-Beam Connecting Rods | juiced66malibu | Engine | 2 | 10-26-2007 07:29 AM |
| high beam indecator light | davedeltadog | Electrical | 4 | 12-06-2005 04:07 PM |
| help replacing the high beam switch | saenz5 | Electrical | 2 | 10-06-2004 06:36 PM |
| High Beam Indicator Light | wolfedog | Electrical | 4 | 02-22-2004 06:11 PM |
