High beam switch for GMH floor mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2005, 01:43 PM
G'day,
I am trying to wire a GMH foot activated (floor mounted, push-button) high beam switch. The box did not come with a diagramme, but there are three wires on the harness: one on the top in the centre, and two at bottom left and right. There are no colours on any of the wires other than black, so thus nothing decernable. The wire harness clicks in place, and the switch bolts to the floor. I was hoping someone on this forum may have dealt with this in the past. The wire unit has male prongs extruding from the switch, and female for the corresponding harness. I thought perhaps the centre post went to earth, but this does not seem to be the case. Any help would be greatly appreciated.
Cheers,
Josh
Adelaide, South Australia
Old 07-16-2005, 02:47 PM
Joshadelaide,
I would say that the single spade is to attach to the head-light switch (power) and the two other spades go to the different circuits, one for high the other for low beam. The lights are to be grounded (earth) at their buckets not at the dimmer.
Have Fun
Scholman
Old 07-16-2005, 08:39 PM
Thank you Scholman,
I will try that. Hopefully I did not ruin the switch, as I assumed the centre to be earthed... until I saw the sparks.....
Cheers,
Josh
Old 07-16-2005, 08:56 PM
G'day again Scholman,
I just tryed your advice, and it was spot-on: works a treat. I would never have figured that, fair dinkum- does explain the sparks, though. I hope I can help you out one day.
Cheers,
Josh
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
help replacing the high beam switch saenz5 Electrical 2 10-06-2004 06:36 PM
High Powered Coil's Question Francis Electrical 3 04-12-2004 03:36 AM
High Beam Indicator Light wolfedog Electrical 4 02-22-2004 06:11 PM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
