High build vs epoxy primers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 10:58 AM
1990_LX's Avatar
Well here's the deal. MY fox was sanded down so that there was a lot of bare metal spots showing. I was told that a 2k high build primer would work for me(it is great and fills in A LOT) so that's what I got. I'm getting some light surface rust under the primer in a couple of spots and now people are telling me that I should have gotten an epoxy primer. I don't drive the car in primer and it hasn't been outside in any kind of rain or snow, so maybe the primer was just really thin in those spots? Did I really screw it up? Should I get some epoxy primer and just put it over the top of the 2k that's on it now or would a primer sealer over the 2k suffice?
Old 04-17-2011, 11:30 AM
put up or shut up
you must have primed over rust to begin with unless it was sitting outside but that doesn't sound like the case. Sounds like you just primed over rust. I'd strip it and ensure the surface rust is completely gone. Then I'd either hit it with a 2k, or epoxy and let it semi cure and THEN 2k it. Epoxy is more dense and sticks better. It holds out rust for longer and provides the best adhesion to bare metal you can get. Just not fun sanding it but it provides a great cross link cure with a 2k and so you don't necessarily have to sand on it.
Old 04-17-2011, 12:26 PM
mitmaks's Avatar
Last journal entry: Grille
Sand it all down to bare metal. Get yourself a gallon of epoxy, shoot it over bare metal and then you can do your bodywork/2K Hi-Build primer over it.
Old 04-18-2011, 07:26 AM
Old Fool's Avatar
Use SPI epoxy and it will sand much easier than mot other epoxys
Old 04-18-2011, 07:36 AM
302 Z28's Avatar
Then apply your 2K over the epoxy. Any areas where you sand through to bare metal should be spot primed with epoxy.
Vince
Old 04-18-2011, 07:56 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
many 2k urethane primers will soak up water like a sponge. main reason i stopped using them. if you need fill go to one of the evercoat poly high builds.
for the money whats the best epoxy primer and the best 2k high build prime fnelson71 Body - Exterior 12 10-04-2009 05:32 AM
SPI epoxy as high build primer? BadHabitSS Body - Exterior 10 07-27-2009 07:24 AM
Epoxy primers ScotY Body - Exterior 30 09-25-2008 07:46 AM
Spraying 2k Epoxy High Build Primer Bucket Man 23 Body - Exterior 7 07-12-2008 01:25 AM
high build primer over epoxy jcarter Body - Exterior 3 02-28-2005 10:59 AM
