-   -   High flow oil pump (http://www.hotrodders.com/forum/high-flow-oil-pump-123714.html)
sexypizzaman 09-04-2007 09:47 PM
High flow oil pump
Can anybody give me a link to a good high flow oil pump for a 383 SBC?? I've been told when making a stroker it is a must for a higher flowing oil pump.
Thanks,
Keith
383silverado 09-04-2007 09:53 PM
you will need a 7 qt oil pan or you will risk sucking the the 5 qt pan dry at high rpms. there is also a high pressure pump also. fyi
http://www.jegs.com/webapp/wcs/store...Ne=1&langId=-1
there is a difference between high volume and high pressure
techinspector1 09-04-2007 09:59 PM
You don't need anything more than a standard pump, but if you're gonna do the high volume/pressure pump, then you're gonna need to open up the clearances on the main and rod bearings to sling enough oil onto the distributor gear to keep it lubed. The pump will require additional work from the gear to turn the pump and needs the extra lube.
There was a thread on here a while back where someone came up with a mod to the distributor housing also, to put additional oil on the gear. I'll see if I can find it.
383silverado 09-04-2007 10:13 PM
could it be like my accel dizzy it has a hole on the shaft to get more oil to the gear.
http://www.duramaxperformancechip.co...ighlight=accel
matt167 09-04-2007 10:48 PM
Melling M55 HV, standard SBC high volume
Rick WI 09-04-2007 11:08 PM
You don't need a HV oil pump.
