High flow oil pump
Can anybody give me a link to a good high flow oil pump for a 383 SBC?? I've been told when making a stroker it is a must for a higher flowing oil pump.
Thanks, Keith |
you will need a 7 qt oil pan or you will risk sucking the the 5 qt pan dry at high rpms. there is also a high pressure pump also. fyi
http://www.jegs.com/webapp/wcs/store...Ne=1&langId=-1 there is a difference between high volume and high pressure |
You don't need anything more than a standard pump, but if you're gonna do the high volume/pressure pump, then you're gonna need to open up the clearances on the main and rod bearings to sling enough oil onto the distributor gear to keep it lubed. The pump will require additional work from the gear to turn the pump and needs the extra lube.
There was a thread on here a while back where someone came up with a mod to the distributor housing also, to put additional oil on the gear. I'll see if I can find it. |
could it be like my accel dizzy it has a hole on the shaft to get more oil to the gear. http://www.duramaxperformancechip.co...ighlight=accel . Last edited by 383silverado; 09-04-2007 at 10:58 PM. |
Melling M55 HV, standard SBC high volume
You don't need a HV oil pump.
| Oil leaking near fuel pump..what the heck??? | HotRodF100 | Engine | 13 | 01-08-2012 05:03 AM |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| 400 Small Block oil problems | bac6772 | Engine | 42 | 07-05-2007 12:49 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Should I change my oil? | 48Man | Engine | 2 | 01-29-2003 07:28 AM |
