Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - High flow oil pump
Old 09-04-2007, 10:53 PM
383silverado's Avatar
383silverado 383silverado is offline
you will need a 7 qt oil pan or you will risk sucking the the 5 qt pan dry at high rpms. there is also a high pressure pump also. fyi
http://www.jegs.com/webapp/wcs/store...Ne=1&langId=-1
there is a difference between high volume and high pressure
