Jugger, you've made me realize that I know little or nothing about high-flow water pumps even after being in this hobby for over 50 years.
I will share with you what makes sense to me. Filling the pump cavity with as much impeller as is possible makes sense. Making sure the impeller is a tight fit on the driveshaft makes sense. Using a solid sheet metal backing plate on the impeller to prevent water from circulating inside the pump cavity makes sense. Possibly increasing the drive ratio off the crank makes sense. I figured out one time that the pump is driven at about 1.2 to 1.3 times crank speed on OEM applications. Maybe a guy could try 1.4 and see what happens. Color me fairly clueless. |
My buddy put one on his Burb well when seeing the better flow I said let me get one as well because one I have underdrive pulleys and this stop & go traffic here in Houston sure can get to ones engine now I have had them on my truck for a while and im super happy with them.
High Flow Water Pump
Thanks for the comments. I guess a common sense approach may be the answer although one would think that the angle of the vanes on the impeller could be at issue besides size, however, none of the pumps that I see advertised amplify on design and I have nothing to compare my stock pump to, so I guess I have to take the word of the advertisers coupled with common sense. Taking that one step further, I would surmise that increasing the turning ratio might prematurely burn out the bearings if it turned too fast all the time (in traffic) and like a marine propeller, could cause cavitation or other unintended consequences.
I know there are experts out there who can shed some light on this issue and would appreciate their insight. Mahalo. David |
| High flow oil pump | sexypizzaman | Engine | 5 | 09-04-2007 11:08 PM |
| High flow water pump for SBC 350 | 75gmck25 | Engine | 7 | 05-22-2007 03:42 PM |
| reverse flow water pump | radshell | Engine | 2 | 05-23-2005 10:03 AM |
| Update on Hi-Flow water pump | Kaylah | General Rodding Tech | 7 | 10-25-2003 11:12 AM |
| High Flow Water pump??? | Dave E Shank | Engine | 1 | 11-20-2002 07:25 PM |
