high gloss finish - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 05:28 PM
mitmaks's Avatar
Last journal entry: Grille
high gloss finish
At my job we're looking for high gloss finish and we've tried a few different types.
Acrylic enamel, modified alkyd enamel, acrylic urethane, urethane enamel.
Imo best gloss came from acrylic urethane. Is there anything else we could try besides going with base/clear automotive finish?
Old 11-01-2010, 07:21 PM
Nope, you pretty much tapped the market out.
Old 11-01-2010, 08:34 PM
mitmaks's Avatar
Imo the best gloss is with Acrylic Urethane, am I right?
Old 11-01-2010, 10:23 PM
The best would be to go with Base Coat/ Clear Coat. Cut and buff, then floss your teeth using a the mirror image of yourself in your cars paint.
Why would you not want to use Base Coat/ Clear Coat?
Old 11-01-2010, 10:25 PM
mitmaks's Avatar
It's just machinery, but higher end machinery so we're using higher grade paint than just acrylic enamel we use on everything else.
Old 11-02-2010, 09:28 AM
In your case, acrylic urethane would give the highest gloss.
There's lots of industrial enamels out there, but none are
very glossy, at least not as much as automotive paint.
Just curious, what type primer are you using, epoxy?
Old 11-02-2010, 10:11 AM
302 Z28's Avatar
Urethane clear is the way to go, but be advised there are varying levels of gloss in urethane clears.
Vince
Old 11-02-2010, 11:45 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
If the acrylic urethane you are using has a compatible clear that uses the same hardener, you may be able to mix the last coat 50/50 for a glossier finish, if the paint mfr. allows for it.
Which Chassis finish would you choose from these 2 options? uglyjeep Body - Exterior 11 10-10-2008 11:17 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
283 vacuum advance nickeldimerods Engine 3 01-14-2006 05:13 PM
High Powered Coil's Question Francis Electrical 3 04-12-2004 03:36 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
