High idle and dies when put into gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2003, 12:17 PM
350 chevy, Edelbrock 750 Electric Choke, Competition Cam (Unsure of model, but idle has noticeable lope).
When I idle the carburator adjustment while the truck is in gear to a solid lope it idles high when in park. And, when I idle the truck in park to an acceptable level, it dies when I put it into gear. Does anyone have any suggestions, comments, or questions that would help me decide the next step?
Old 08-11-2003, 12:30 PM
Dozier768's Avatar
did this prob just start out of the blue? or is this a new combo? if its a new setup i would guess its a case of too much cam not enough stall in the converter. if you could find out what cam you have and what torque converter you are running it would help.
Old 08-11-2003, 12:55 PM
It has been hapening since I purchased the pickup (69 Chevy). Do you have a suggestion on how to locate the cam and stall information without pulling them. Also, if I pull the cam does it have an OEM part number on it?
Old 08-11-2003, 02:25 PM
Dozier768's Avatar
pull the cam gear off and look at the face of the camshaft there should be a part number on there, well typically. if there is post it and well try to identify it. it is possible the part number is on the backside of the cam, if thats the case then youll have to pull it, if its a flat tappet cam make sure you keep ther lifters mached up to the proper bores.
Old 03-23-2012, 05:31 PM
did you ever find the problem? my car is doing the same thing
Old 03-23-2012, 06:21 PM
bigdog7373's Avatar
Of course it's fast
Dude really? A 9 year old thread?
