High Idle on MFI - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2006, 08:01 PM
bluesman123's Avatar
High Idle on MFI
I have a hi idle on an MFI system. This is an L31 in a Sonoma (350 Vortec with the MFI system), basically stock with the exception of a cool air induction and more open exhaust. I have checked the linkage and it seems free moving. There are no codes being thrown. If I hold on the brake the idle slowly comes down to where it is supposed to be.
Any ideas are GREATLY appreciated!!
Dave
Old 09-16-2006, 08:34 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Without scanning the data from the pcm, it can be difficult to diagnose that problem. Most likely problem is a vacuum leak. A bad IAC valve can cause high idle. A bad pcm can cause it as well. A bad TPS can cause it. But those things usually WILL set a code. Im not telling you to go throw a bunch of parts on it I just pointing out possibilities. Is it Mass air flow system?
Old 09-16-2006, 09:02 PM
Yeah I'm with you about throwing parts at it. The thing that has me puzzled is the lack of a code. I was thinking about the IAC, but hate to just throw another one in there. I will check for vac leaks and see if I come up with anything.
dave
High idle and dies when put into gear hotrodtodd Engine 5 03-23-2012 06:21 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
High Idle Slant3 Engine 4 08-30-2004 12:37 AM
sbc 350 miss under idle Walker Engine 2 07-29-2003 09:02 PM
Q-jet high idle COCHEV Engine 6 06-29-2003 05:04 PM
