-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   High Low Beam column mount switch? (http://www.hotrodders.com/forum/high-low-beam-column-mount-switch-131443.html)
Stovebolter 01-12-2008 09:51 AM
Does anyone know if the combination turn signal/hi low beam switch off a newer model will fit any of the aftermarket columns? I'd like the hi/low beam to be on the turn signal switch but cant find a column in the salvage yard that is simple and clean like a 79 Camaro column.
Thanks,
Dave
Deuce 01-12-2008 03:54 PM
http://i2.ebayimg.com/07/i/000/b1/c7/bbc3_1.JPG
http://i11.ebayimg.com/06/i/000/b1/c7/bb51_1.JPG
I always just use a floor mount type ... like from a GM vehicle from the late 60's ... easy to wire, easy to use and easy to mount.
Also easy to replace if you ever need to. All the ones I have ever seen that mount on the column are large, bulky and not very attractive.
I always use a GM van tilt column and they are small and do not leave a lot of room for a BIG ole turn signal switch.
http://i3.ebayimg.com/04/i/000/d0/9f/0dd0_1.JPG
If you really want a turn signal/high - low beam changer on the column ... I suggest looking at a later GM van tilt column.
http://i4.ebayimg.com/08/i/000/d0/f6/d9dd_1.JPG
They are plentiful in supply and cheap to buy ... no one much wants them because of the bulk .
Stovebolter 01-12-2008 04:07 PM
Thanks Duece. I guess I'll just stick with the floor mount like you. I just thought it would be nice to have everything I can on the column.
Dave
MI2600 01-13-2008 10:24 PM
I don't know Deuce, I think one of those first switches you showed would look a little funny duct taped to the steering column...LOL
1969NovaSS 01-13-2008 11:16 PM
I recently rewired a 58 apache and the guy wanted to use the multifunction switch from a 79 camaro. The high beam switch had the same connector that would have gone to the floor mounted one. The big connector has 2 extra wires that arent needed. the connector is also a a different size so take one from the donor car and just pull the pins out.
Stovebolter 01-14-2008 10:00 AM
Thanks guys for the help.
Dave
